Flickering HID...help!
  • Flickering HID...help!
    Well me and my boy washed and cleaned his engine bay yesterday and now the driver side HID wont stay on, it flickers like a strobe light and then dies after about 10 seconds. He had another set of HID's so we swapped them and it did the same thing, seems like something electrical....whats going on with it???????
    I like my women like my engine bays..clean and shaved!!
    ~~~Corners>Straights----
    sounds like one of the ballast got wet? i say leave it off let it completely dry aND see what happens
    R.I.P Nick aka NHSwaps
      is it plug and play or did you hardwire it
      white people suck
        plug an play and i figured it got wet, but we swapped out the hid + ballest for another one that he had laying around and it still does it with the new one so it seems like its something electrical
          check ya grounds and power and make sure no wires are loose
          white people suck
            i was thinkin the same thing bout the ballast but u said u changed them
            203 Crew Memeber # 57
              Check ballast.. Sounds donzo!
                Check your wiring
                S3-R
                Stage3-Racing
                  check your ecu.......lol
                    Had the same problem wit mine..its a loose wire
                    Originally posted by 95ejvtec
                      lmfao
                      S3-R
                      Stage3-Racing
                        Try changing your fuse
                        *S14 Kouki *
                          try changing your dizzy.
                            forealz?
                            *S14 Kouki *
                              Originally posted by JDM8o9 View Post
                              forealz?
                              yea. and if that doesn't fix it, replace you drivers side outer tie rod. Hid will be brighter then ever after that!
