Eg Manual Steering Rack Onto P/s Integra Subframe
  • Eg Manual Steering Rack Onto P/s Integra Subframe
    I have a subframe from a 98 integra with power steering and a brand new eg manual steering rack what is the right way to put it on. I know you need to change some stuff for it to bolt up to the passenger side of the subframe but wanted to see if it is even worth doing or just go out and buy a eg subframe. any help is appreciated thanks
    I have an eg subframe lmk
          I know this is old, but I'll answer the question in case anyone wants the reference in the future.
          The rack will bolt up.
          The issue is that the manual rack is a smaller diameter, so the C shaped bracket on the passenger side of the rack is too large.
          The C shaped bracket from a manual rack subframe won't bolt up to a PS rack subframe.
          You can use the C shaped bracket from the PS subframe with the manual rack by wrapping the rack in 2 bushings instead of 1. I recommend that at least one of the bushings be polyurethane, so as to limit deflection. The rubber might be too soft.
