Em1 spindles on ek hatch
  • Em1 spindles on ek hatch
    I have a set of front spindles and rear disk from a 99 si coupe. I want to put them on a stock 2000 ek hatch.....Would I be able to just throw the spindles on and lines with no problems? I kno I can do the rear disk but was wondering if I had to change anything in the front to put the spindles in? thanx.
    Fronts ur good to go rears u should be good to go also if complete
      Ya the backs are all complete
        Direct bolt on.
          No problems if u have everything
            Then ur good to go
              The only thin you'll need if it's not on your rear disc is Integra/em1 rear brake hoses.
                That's y I asked if it was complete LOL
                  Yaa I got tha hoses only thing I was stressin is if I had to change the lower control arm in the front or the horse shoe up top...I assumed it be same since its ek but still wanted to be 100% rather be safe then sorry
                      its all direct bolt on as long as you have calipers and all.your proportional valve on your hatch does NOT have to be changed.its already a 40/40 .the same as a civic si one.but it would be best for you to change your brake booster and master cylinder.but will be fine without it in the meantime.im running 5 lug on my hatch with my stock parts.
                      Originally posted by knuckk
                        Bump thanx bro..and ya I have the calipers from the si
                          Yoo do u know if ima have to change out the front lower arm and forks?? Cuz I checked the part numbers and a si's fork and lower arm is diferent in the front
                            U shouldn't but if u do I think I got the ones u need
                              you dont need to change anything the front lower arm is only different cause it has the spot for a front sway bar other than that they are completely identical
