***tires wearing to fast***
  • #31
    Maybe u have cheap ass tires and the summer heat is killing them lol
    • #32
      lol nah...they were Nitto Gens
      • #33
        Originally posted by eyeamthe1
        Ok so lately i have been going through tires like water. Im riding on cut springs btw...what could be the problem??
        Lmaooo bro you answered your own question "CUT SPRINGS" who does that anymore seriously? You can get a set of tein springs for 140 shipped to your door or other companies a little cheaper.. Get rid of them garbage springs and get some real springs and a camber kit , then go get an alignment and you'll be good.. Not trying to bash but try and help you ouy
        R.I.P Nick aka NHSwaps
        • #34
          So my cut springs are wearing the tires fast?? What if I get an alignment with cut springs??
          • #35
            You can try not sure if it will help? But def look into aftermarket real springs bro and a camber kit and you'll be good
            • #36
              Bump for an attempt to troll but failed instead.
              • #37
                thanks! i already got a camber kit on there. i just need coilovers now
                • #38
                  lol and you dont know your problems because what?
                  • #39
                    • #40
                      you have cut springs and you have not clue what is wearing your tires because what again?
                      • #41
                        2036066231 text or call I do alignments
                        • #42
                          you have a few things that are likely causing this ^^^
                          cut springs wont cause tires to wear fast directly, but it'll cause suspension components (ie. shocks, ball joints, bushings) to go bad and these going bad will cause a premature tire wear.
                          plus
                          UTQG Treadwear: 280
                          Traction: AA
                          Temperature: A
                          low numbers of treadwear means the tread wears more easily as this is to stick rubber better on to the ground(pavement) better traction less tire spinning
                          also always check the tire rotation... lots of performance oriented tires demand for correct rotation, and not orienting the rotation in the correct direction will wear the tire prematurely.
                          don't know if people know this but coilovers are for circuit racing, meaning for cornering at high speeds and are intended for adjusting the rides height and stiffness on all four corners, but these weren't designed for daily driving at all...
                          my recommendation is check your suspension componets, and replace everything that is not up to specifications; ie blown shocks, ball joints, tie rods... then alignment is a most if you want to keep them components in a good condition, just remember its your ride and your money!! so only you can decide what goes into your ride.
                          hope this helped
                          honda sale thread
                          call/text 203-510-5710
                          • #43
                            Alignment could help a lot..but get lowering springs
                            Ek coupe-dd
                            Daddy to be
                            Twisted Jokers Ac-Lieutenant
