Or you can piece together your own 5 lug and save some money.Thats what I'm doing. I'm almost done. All that's left for me to put my 5 lug on the car is rotors/pads/tires for my prelude wheels.
Itr 5lug vs ctr 5lug
U use Integra or civic Si rear disk trailing arms. Your remove the hubs from the trailing arm and u can use prelude(97-01) or Itr rear hubs. The prelude 97-01 rear hubs are cheaper to buy.u can use rear rotors from a Rsx or Itr.u can use rear calipers with brackets from a Itr/Rsx/ep3/ctr/jdm Itr...Rsx and ep3 will be the cheapest to buy. If u buy Rsx rear calipers,u will have to place the left caliper on the right side and the right caliper on the left and u will have to place your E brake bracket from the Integra or civic Si to the Rsx rear caliper so that your E brake cable will bolt on like factory.for the front u can use Crv 97-01 spindles complete with calipers,rotors,pads and axle ends..or Crv spindles with prelude,Itr rotors,calipers,brackets,pads,etc. They are all the same. There are several other cars that use the same calipers for the front as Crv,prelude and Itr. But with the Crv front spindles,you will need 36mm axle ends since civics 89-00 and Integra 90-01 are 32mm axle and not 36mm like the Crv. So your basically combining two axles to make one(32mm on tranny,36mm on spindle side). U can use axle ends from a Honda accord,97+ prelude,jdm Itr ,etc. There is other ways to get the rears done without having to buy all those parts. You can buy custom rotors for the rear from a member on k20a.org..he sells them for $100 shipped (pair) and that will allow you to use your Integra/civic rear calipers and caliper brackets. Or u can use a prelude/itr hub and redrill your 4 lug rotor. But either way will leave u will small rotors,pads and calipers in the rear but it will work. So it's up 2u on which route you decide.you can use the prelude or Mazda 626/protege rear axle nut with loctite and it's best to add some tack welds for safety. Torque the rear axle nut to 134 ft lbs....83ft lbs for the rear caliper bolts..80ft lbs for the lug nuts
*****I listed all this info because I keep getting PM's from members asking me on what's needed,etc and I don't want to keep repeating myself.Last edited by jdmdikk; 06-22-2012, 09:07 PM.Originally posted by knuckk@jdmdikk only dude i would take advice from.
Originally posted by jdmdikk View PostU use Integra or civic Si rear disk trailing arms. Your remove the hubs from the trailing arm and u can use prelude(97-01) or Itr rear hubs. The prelude 97-01 rear hubs are cheaper to buy.u can use rear rotors from a Rsx or Itr.u can use rear calipers with brackets from a Itr/Rsx/ep3/ctr/jdm Itr...Rsx and ep3 will be the cheapest to buy. If u buy Rsx rear calipers,u will have to place the left caliper on the right side and the right caliper on the left and u will have to place your E brake bracket from the Integra or civic Si to the Rsx rear caliper so that your E brake cable will bolt on like factory.for the front u can use Crv 97-01 spindles complete with calipers,rotors,pads and axle ends..or Crv spindles with prelude,Itr rotors,calipers,brackets,pads,etc. They are all the same. There are several other cars that use the same calipers for the front as Crv,prelude and Itr. But with the Crv front spindles,you will need 36mm axle ends since civics 89-00 and Integra 90-01 are 32mm axle and not 36mm like the Crv. So your basically combining two axles to make one(32mm on tranny,36mm on spindle side). U can use axle ends from a Honda accord,97+ prelude,jdm Itr ,etc. There is other ways to get the rears done without having to buy all those parts. You can buy custom rotors for the rear from a member on k20a.org..he sells them for $100 shipped (pair) and that will allow you to use your Integra/civic rear calipers and caliper brackets. Or u can use a prelude/itr hub and redrill your 4 lug rotor. But either way will leave u will small rotors,pads and calipers in the rear but it will work. So it's up 2u on which route you decide.
look at his sig. i state the truth.knuckk.
Originally posted by IBaRbErI View PostThnks jdmdikk, deff keep in mindLast edited by jdmdikk; 06-23-2012, 08:57 AM.Originally posted by knuckk@jdmdikk only dude i would take advice from.
