POOR MANS 5 lug conversion
  • POOR MANS 5 lug conversion
    Want to know what's needed for a 5 lug conversion on a dc2 gsr still using trailing arms.
    "JDM FAM" is out here to stay.....
    UKDM Type R Replica DC2 All Motor GSR
    Most people say that it will cost the same or more then buying real type r suspension and that it's a waste of time. Plus it's not as safe.you can google your answer and find plenty of answers on what's needed to piece your own setup together
    Originally posted by knuckk
      no Machine shop will do it in ct maybe out of state ull find a true puerto rican thatll do it for u lol if u talking about redrilling ur stock hubs
      checos autoworks
      *Goldstar*
        Hmu I know someone
        The Power of Dreams
          Lol no he means using his existing suspension nd putting new hubs/prelude junk on his dc2 I have researched the shit out of this subject its easier nd just all around better to just buy the 5lug conversion who wants to go to a autoparts store nd say I need prelude wait itr wait crv rotors nd pads its better to have all the same components some r smaller (prelude) compared to crv nd jdm/usdm itr u can use ur gsr rear calipers if u go the prelude route
            Basically anything u need to kno there is a write up on Honda tech I'm sure I just summed it up get prelude rear hub assembly nd front press em in u can use ur gsr rear calipers nd mounting brackets as for the front u need the prelude front hub wheel bearing assembly nd press that into ur dc2 front knuckle prelude front rotor nd ur gsr front calipers might or might not fit I'm not sure on that but prelude got to be better seeing how its bigger lol
              I read something about crv front knuckles and all other components and for the rear rsx type s hub, rotor, bracket, calipers. Just wanted to see if someone out there has done it. Don't want to do it unsafe or cheap, rather get the real shit if no one can show proof of it being done with these parts.
              Who got one for sale?
              USDM FIVE LUG CONVERSION??
                U must have read the thread on k20.org lol. U can use Crv front spindles/knuckles (hub/rotors/caliper,etc) they are basically the same as jdm Itr spindles/knuckles. they are perfect for k series axles.or u can use 36mm outer axle section and place it onto your 32mm axle
                  knuckk.
                    Honda/Acura 5-Lug Swap Using 4- Lug suspension This setup/thread will be edited as time goes on. Disclaimer: I will not be held liable for any damage or accidents that may occur from this due to improper installation. We are all adults so whoever decides to attempt this, use it at...
                    Some very good info on that forum.
                      Thanks jdmdikk!!! Great info A++!!!
                        I just told u that a couple days ago lol
                          Funny dudes asking for info I give him the cheapest way possible nd he doesn't even say thanx glwyf I kno 5lug in and out if ur ready to do this let me kno I can get u 5lug shipped to ur door done the right way
                            Yes thanks to you 2, it's my first time really using this. Im sorry that I left one person out!! If u know about the topic then leave feedback I will take all advice, when someone doesn't know you teach!!
                              All the info on what is usable is all over the net. I was simply sharing info with the op to help him out. I myself would have done my own poor man type r 5 lug if my car had rear disk trailing arms already but it doesn't. So I would spend more at the end I would assume.
