5lug question
  • 5lug question
    Ok so I wanna go 5 lug again but I don't want 36mm axles.. my question is can the hubs be swapped out to 32mm?? And I kno usdm type r comes wit 32mm so keep the slick comments to urself... I just don't feel like waiting for somebody to "POP up" wit usdm suspension so if I could swap out the hubs ill just go to the depot...
    usa los del crv mamao
    checos autoworks
    *Goldstar*
      Son 36 mm... Los quiero 32..
        Just get civic type r 5 lug they come 32mm already ....damn bro you never hitme up i can help you with all of this :(
          I got my 5 lug 36 mm with axles for $800 shipped to my door mint as fuck complete brake cables but I get what ur tryin to do the hub is bigger nd I kno a Usdm type r wheel bearing won't fit so ur question is no ur better off just getting the Usdm 32mm. Axles r $200 for 36mm
            I had Jdm civic type r ones on my hatch and they were 36... I just wanna be able to use the axles I have now..
              What site was that?
                Originally posted by 93eg2sol View Post
                What site was that?
                X2
                Straights are 4 fast cars. Corners are 4 fast drivers.
                  CTR is 32mm. You had jdm itr if it was 36mm.
                    I got em from the depot and they had civic type r written on the rotors so I'm assuming they were ctr...
                      Ahh. Yea then they were marked wrong. Bring a 32mm ale next time and double check before you buy.
                        No they were itr.......ctr is 32mm
                          Damn they burned u bro jdm ctr is 32 usdm itr is 32 nd jdm itr is 36 if u want 5lug for dumb cheap just go to the junk yard nd buy front 99 crv spindle assembly nd get the rear hubs bam dumb cheap then just mate up crv cv joints to ur 32mm axles
                            Nah I don't like riging or doin shit the cheap way.. u always end up spending more when u go the cheap route... Ima look for ctr suspension then I guess...
                              Those r also $800 to $1000+ on eBay glwyf its ur only option if u want to keep ur 32mm axles
