Brake Light Help
  • Brake Light Help
    The brake light that goes on when you have the e-brake applied, stays on when the e-brakes not applied what good this be?
    Brake booster.. there is a diy in the haynes manual to determine exactly what it is
      ^^ hmm learned something new. What car is it?
        Your fluids low
        Originally posted by LS/Vtec
          My brake booster is good thoug I get all the power I changed my master cylinder recently but ain't bleed the brake by pumping the brake I did the pre bleed on the master cylinder could that be it?
            Nope fluids aren't low and it's a 91 civic 4dr
              Gl bump I have no clue
                Thanks man bump ppl
                  Check the wire going to the ebrake
                  NHSWAPS13203 > *
                    Located under the center consul?
                      Yea , i belive the hand brake when applied grounds the wire, if the switch or wire is caught up or grounded the light will come on
                      NHSWAPS13203 > *
                        shit gets annoying when u have lights on ur cluster cuz my seatbelt light be staying on sometimes n i be heated lol
                          Yea man bad enough I got a check engine and wanna know what that is also who on here could read that for me?
                            x2 thats probably the fix right there
                              yeah my e brake lights stays on too its annoying
