I put s-techs on my car over the weekend and now my rear wheels have positive camber( they are sitting straight up and down). The car is all over the place on the highway. How do i fix this, alignment, camber kit, or ? Please help
My tein s-techs gave me positive camber, HELP
ur bushings could be shot that could also be another reason
AIM Luvaluva6901
Parts for sale
What year is it? If it's older (ef at the very least) there is nothing the alignment shop can do. I would double check and make sure everything it tight. Did you swap anything else out when you put in the new springs? What I am thinking is your upper control arms are sitting farther out (bad bushings), your lower control arms are being pushed in (bad bushings), or your wheel bearings are no good. Maybe try to move your rear tires around with the back of the car jacked up to see if there is play. If there is you can go from there and see what is causing the play...My work: Flikr.
