itr suspension on my stock crx si , need help asap
  • itr suspension on my stock crx si , need help asap
    itr suspension on my stock crx si. need help asap
    Hey ctvtec I need real help no guessing,
    I have a 91 crx si that I'm keeping the motor stock , but I bought a five lug conversion, I understand the whole machining thing I also need a place that does that, but I was told me itr 32mm axle splin won't fit with the stock crx si axle.
    Please help I need real facts, and a place that can machine my hubs thanks.
    To my knowledge it should fit if u have 32mm 5 lug... where did u get the suspension ?
      Hit up naisbest13203 he did the same conversion on his old kswaped crx si
      "cocaine coupe" aka "kilo"
      R.I.P Alex Soto aka "SUPER SOTO" "KING OF SPRAY!" 09/17/12
        Problem is if its a Jdm 5 lug its 36 mm axles then u have a problem... if its 32 mm u good...
          also make sure you change your stock front lca's to integra lca's if not your front tires will have negitive camber
            That's one thing I never heard of. I was just gonna get a camber kit for the front and rear.
            Ok so all Honda 32mm splines are the same on the axle.
            Now I just need a place to get them machined with my da spindles
              His name never came up.
                i say it cus i put gsr disk all around on my 88 crx hf and i guess the stock lca's are shorter than integra lca's so my front tires looked crazy so i changed them to integra lca's and it was perfect
                  Just Google it same size length, only difference is where the tractionbar whole goes
