Tired of buying lower control arms only to find out your bushing's are bad the next year!!!!
Easy solution, you most likely put them in wrong. LOL. I found out after my first set that if you raise your car up and put your bolts in all the way, that you are setting the bushing in at the wrong angles.
Simply put your bolts in (all 6) in half way, lower your car, push down on your trunk a few dozen times then tighten them when it settles!
Boom baby saving money and time.
Niceguy.
Niceguy.
