ok I have an eg ex coupe when shifting it feels like its hard to get into gear like I have to force it in... and when shifting it doesn't feel smooth like it should you can feel it pop out when you shift from gear to gear....
Here is what I've tried so far:
Changed tranny fluid
Loosened the bolt that holds the short shifter
I was told I probably need to adjust the clutch pedal because it grabs extremely low
Mind you my car was auto and I swapped it to 5 speed so I believe it has something to do with the pedals adjustment...
Any1 have any input?
Any1 know how to adjust the clutch pedal? Lmk I need it done asap
