for the last couple weeks my brake pedal felt really soft.... i thought it might have been my front brakes... so i upgraded to the whole si spindles... the brake pedal stil felt soft after bleeding the brakes so now im thinking its my rear shoes... but just the other day i was speeding and some dick head cut me off and i slammed on my pedal, i felt something squirt out from my firewall.. and now after couple miles my car is in need of brake fluid.... does anyone kno wat this can be??? any answers will be gladly appreciated thank yu...
brake failure help....
Originally posted by d&gauto View PostCould be leaking inside the brake booster from the master cylinderOriginally posted by Deathwish203Im on welfare...can i get a better deal???where u located
Originally posted by SeanJDMJohn View PostThat what I ment to say master gasket is bad in-between the master nd booster or the whole shit could just be bad all together if u felt a squirt on ur leg or something DO U SEE ANY FLUID ON UR CARPET OR NE THING
Okay I kno this cause I did my booster 180 to tuck the vacume hose when u take the two nuts off to take the master cylinder off the booster there is a rubber black gromet with a whole in the middle for the push rod ill get pix for u nowOriginally posted by Deathwish203Im on welfare...can i get a better deal???where u located
Originally posted by SeanJDMJohn View PostOkay I kno this cause I did my booster 180 to tuck the vacume hose when u take the two nuts off to take the master cylinder off the booster there is a rubber black gromet with a whole in the middle for the push rod ill get pix for u now
thanks broo.. this will be very helpful. pic will also help alotNO bullshit YOMO RACING TAKIN OVER!!! 413 ALL DAY
HERE U GO THIS IS A PIC OF THE BLACK RUBBER GASKET/GROMMET I'D SAY CLEAN IT UP
TWO THIS IS A PIC OF THE MASTER U SEE THE CROME PUSH ROD THIS IS WHERE THE GASKET SHOULD BE LOCATED OR IT PROBLY WILL STILL BE IN THE BOOSTER HOLE TAKE IT OUT/ OFF BUT IF U DO ALL THAT I WOULD JUST GET A NEW MASTER UR WELCOME JUST TRYIN TO HELP WIT PIX
