traviling at high speed
  • traviling at high speed
    Hey what the problem or what has to b fixed when ur driving at high speed on the highway and the steering wheel shakes alil is not bad yet so I want to jus fix it b4 it gets bad I want it to b smooooth is that mayb a wheel balance or sumthing of that nature?! Lmk thanks
    Wheels out of balance or out of round
      Or bent rim(s)
        What he said^^
        WILSON BUILT
          if not that, wheel bearings. push the wheel and see if it wiggles back and forth
            Ive even had a bad axle do that.
            Balance tires, make sure there is no bubble in the tire or flat spot, check the wheel bearing, etc.
            RIP NHSWAPS13203
              def wheel balance, bubble...
                could be a tie rod end. mine started shaking at like 60-70mph but not below that and it was a bad tie rod
                  out of balance wheels, belt shifted in a tire, bad suspension parts, warped brakes, etc.
                  first thing to do is get the wheels re-balanced. it's the most likely and easiest thing.
                  590852836f5fbce940_b
