brake problems need help
  • brake problems need help
    Soo my brakes stopped working while driving I check the fluids n it was low so I put sum in and its draining out from my driver side rear drum I have a 95 civic coupe and the brake fluid is coming out from the bottom of the drum in the crack and I don't know how the separate the drum to c wat is going on in there can sumone help me out how do u separate the drum and if I separate them can I fix wat eva is causing it to leak?! Or what do I have to do?! Anyone know?!
    Have someone check the wheel cylinder...
    You're gonna have to bleed it too.
    Word.
      What this dude said above. Def leaking form your line or wheel cylinder. I had the same problem way back when and it was the wheel cylinder. They are only like $25 from autozone i think.
        check your line... i had similar problem and my line was sliced
        NO bullshit YOMO RACING TAKIN OVER!!! 413 ALL DAY
          bump lines look its comin from behind the drum sumwhere
            its ur wheel cylinders for the brakes it pushes ur drums out it prolly shit the bed
            D and G auto member #5
              ^This.
              Like we're all saying bro just pop off the drum and peel back the wheel cylinder boots and check for brake fluid.
              And when you bleed it bleed the whole system (( All 4 corners ))
              Word.
                How do u split them apart? I took the wheel off n then the big ass nut in the middle off then 2 screw in the bak top of it I think they were 10s n it still won't split apart??
                  bump...
                    Buuump
                      Umm... Did you get the drum off ?
                      Word.
                        ummm almost there is 2 pins on the back bottom that wont release it!!!and its pourin outside so i quit lol
                          Lol...
                          Keep us posted on how it goes bro...
                          Word.
                            finished and fixed!!! finally got my baby on the road again lol
                              Lol... Good to hear bro.
                              Word.
