I got a set of ground control sleeves. Everything as far as the install went smooth up front but when I got to the back I ran into a Lil trouble. The head of the bolt for one side snapped on me, typical. This happened after I installed one rear coilover already on the driver side. The passenger side strut bolt snapped.
Anyways, I lowered on stock struts (I kno, I kno, not the greatest idea but whatever). On the stock rear struts there's a cup like perch for the stock spring to sit on. Now when I put the sleeve over the rear strut it goes down into the cup. if I lower the sleeve to match the front or even if I lower the sleeve to the spring perch the adjustment nuts on the sleeve sit on the spring perch <not lettin me go low enough in the back. I hope I explained this enough/correctly lol. Somebody, please help.
