crx spindle swap
  • crx spindle swap
    So I got a 90 si crx which I put 95 integra spindles in the front for bigger brakes but now my caster and my camber alignments are off I'm thinking maybe I had to use DA upper n lower control arms? But I'm not sure I need some opinions
    Working in Silence 203
    camber kit.
    My transmission's went 9's
    http://youtu.be/z2PHemIp_Tg
      You have to use DA Spindles. DC Spindles will not work. The problem is your spindles. Not control arms. Get DA ones and your good to just bolt em up with no camber kit or anything.
        random i used dc and i was fine
          your both right,,,but you need a camber kit it sounds like to me and youll be fine,,but in the first place u should have used DA spindles
            x2 the DA spindles just go right in the DC ones need the camber kit for the caster and camber to line up right
              Oh, I was always told DC ones wont work. I even looked it up one day cuz I was bored.
                Wat car model shuld I choose for the camber kits bcuz I got crx camber kits pushed all the way bak n the camber is still off n the caster shuld I get camber kits for a DA?
                  if your still not getting the proper camber with a camber kit than you just might have to switch to DA spindles,,
                    this is classic i figured id add to this weeks later.... so i put my dc front knuckles with prodrive hubs and gator axles in my crx. Aligned it today ..... and the fucking car is mint, thanks to my buddy jeremy he let me use his shops alignment machine aligned it myself any everything is in the green no camber kits no nothin lol.
                      Bump!
