rear disk
  • rear disk
    will a da rear disk/trailing arm setup fit on a eg
    nah i won't you need a 94+ integra rear disc it will bolt up.. da disc are for 88-91 civic/crx
      alright you sure man?
        i'm positive... get it for a 94 and up integgy bolt right up.. make sure you get e brake cables for the swap
          new cables to the lever and from what model the civic or teg? And what about a bigger master cyl?
            get the cables for the teg and do the master cylinder replace.. you going to need the pressure...and you be set..
              Yes it will fit. But you must use DA trailing arm bushings no matter what vehicle it is going on.
                I always just used 94 and up teggy trailing arms.. always make my life alot easier..
                  Ahh. Well they rears fit. Fronts they are differ.
                    it will fit only difference between trailing arms 90-93 and 94-01 is the size of the main bushing and the lca's/uca's
                    !!!!!ThE GoOd DiE YoUnG!!!!!
                      so what will i have to do? I might just wait and fine a 94+ setup
                        itl fits.
