e brake for swapped brakes
  • e brake for swapped brakes
    I recently purchased an ej1 with 95 gsr rear disc. my question is ... is the e-brake cable the same. my car currently has no e-brake and I'm wondering if you have to use the cable from a gsr. Help would be appreciated.
    All th same
    Follow me @bolacan413
    Follow the build @k_insight
      well from what i know you need to use the e brake lines from the gsr or ls
        i did the disc brake swap too on my car i used the e brake cables from the 1995 ex(abs) civic.but you can use e brake cables from the integra 1994 -2000,or cables from the eg si hatch
        CGP CL9
        1993 EH3
          Originally posted by jealous1shateric View Post
          All th same
          thanks for the help!
