How many of you guys experience frozen LCA bolts?
This is a sticky topic.
  • #16
    If you have never had that problem then you havent done enough hondas or cars period. i have ran into this problem quite a few times. i will use the torch for this you can buy the kit at harbor freight have the bottles filled and your good for other things also.
    860 member #18
    puerto roc #1
    Cosa nostra
    ASAPRadio.net
    • #17
      x2 ive had this happen several times,,its 50/50 if itll break or not,,i hit the head of the bolt with a hammer a few times nd just go for it with a half inch wrachet,,if it breaks w/e just cut each end off and put a new bolt in..
      • #18
        man my shit snapped and i grinded that nut off thats welded to the car so i can get the controll arm out... i wasnt able to get the rest of the bolt out of the bushing so i just threw an new bushing in there and called it a day
        • #19
          it seems like everytime im doin anything back there on a custumers or my own cars u think everythings goin nice and dandy.... AND THE LAST FUCKING BOLT IS FUCKING FROZEN!!!!!!!!!! EVERY FUCKING TIME. Its not even the bolts they stick to the races of the bushing thats why lube works wonders lol.
          My transmission's went 9's
          http://youtu.be/z2PHemIp_Tg
          • #20
            ^^ Very tru, shit happened 2 me idk how many times. On customers & my cars..
            Everytime, I ended up fukin up the bushing, suks ass
            RiP NHSwaPS13203
            IntegraNation Member #13
            • #21
              i always run into problems with the bolts and it's a bitch. i dye grind that shit.
              • #22
                it comes down to the fact that if your taking those bolts out your changing the lca's that all there is to it.
                • #23
                  Finally lowered my car, it was a 3 day process because of the cold weather in my garage and my dremel over heating but its finally done.. The subframe lca bolts came out like nothing and the hub lca bolt was siezed so I had to dremel the bolt on both sides and breaking the 3 spot welds on the nut holding the bolt.. What a stressful situation it is..
                  • #24
                    I soaked the bolts in PB for a night, came back to it did it again and still broke 4 of the six bolts. I used a saw zall to cut the snaped bolts out. I got 2 bolts out without breaking, went to acura in canton to get new hardware, 10bucks a bolt. You can cut a bolt out in like 10mins with the saw dont cut anything else though.
                    • #25
                      where can i get new lca bolts
                      ebay ~ Made
                      • #26
                        i just say fuck it! that shit happens to me all the time!! i usually hit it with pb blaster, tighten the bolt, hit with pb again, then try to loosen it up!
                        ~StayinFRESHSINCE1982~
                        SPUNKY MONKEY CREW MEMBER #1
                        203 CREW MEMBER #33
                        • #27
                          honda!
                          203 CREW MEMBER #33
                          • #28
                            I'm only rocking one blox arm becuz I fear breaking bolts while doing the other side lol
                            • #29
                              go pick up a gun! thats the best way of doing things!
                              203 CREW MEMBER #33
                              • #30
                                Ya a real gun to end the suffering
