got a 91 crx with omnis and slip streams other than that its stock. Had the car aligned but everytime u get on the gas it pulls right other than that its fine. The only thing i saw wrong with it was the front lca bushing were kinda fucked, and i dont see how it could be tork steer with a stock motor, any thoughts?
pulling
pulling
My transmission's went 9's
http://youtu.be/z2PHemIp_Tg
91 crx si boosted sold, 92 hatch boosted sold, 95 coupe supercharged sold, 90 hatch ctr spray rip, 88 crx si fully restored rip, 89 crx si xsi swap rip.Tags: None
Alignment tech here. Control arm bushing at frame could cause camber/caster to change under different load conditions (braking, accelerating, and steering). Caster and camber are pull angles. Camber and toe are wear angles. Also corner weight imbalance could cause pulling under load.(860) and beyond
#DavesTuning 8608050968
dave u know i love u gettin energy bushing this weekend ill check the ones closest to the frame as wellMy transmission's went 9's
checked inner lower control arm bushings and there mint car is still pulling re did every frame bolt and check front bushing that go cross member to lca str8 as well anyother thoughts?My transmission's went 9's
