what brakes will fit and what do i need?
rear disc brakes in a 91 EF
Have you tried to search for writeup?
laziness.
u could use any it dont matter some guy is selling some hond rear disc convo for 250 obo he has everything u need look it up installation is very simple u take like 4 or 5 bolts out i forgot what there called ... i kno its 17cm and 14 cm you are also gonna need a 8 inch exstention...pm if u need my number i could talk u thru the whole process VERY SIMPLELast edited by sir_ef9; 09-27-2009, 08:45 PM.
im in the middle of that right now...you need the trailing arms obviously but then your going to need the piece of brake hose from a 90 integra with the arms. then you are going to need the prop valve from a 90-93 non abs integra and it is a good idea to use the master cylinder from the integra as well. then that should be everything you need...im still looking for the prop. valve right now.
