Need 2 get this body kit off.
  • Need 2 get this body kit off.
    its molded on. any ideas? most of the bondo is cracked.... i need 2 get it off
    LS/T :D :D haha still workin on her.
    just take body hammer and start chizling
    ~StayinFRESHSINCE1982~
    SPUNKY MONKEY CREW MEMBER #1
    203 CREW MEMBER #33
      ok thanks man, my cuzin who works 4 a body shop was gunna just cut it? but i was gunna have 2 pay like 70 n hour
        Ok, Get on your hands and knees, Check where the quearters meet the kit ( you will feel it) mark it, UNBOKT the rear bumper from wherever it has bolts, Use a die cutter along the line you marked. Bam theres the rear bumper off, Reapeat alll the way around the car. (try not to crack the bondo on the quarters becuase you never know how much rust is behind there ya kno)
        Use 80 grit sand paper to round out the endges where the body lines should be (the rear quarters, front fenders and rocker panels etc) then smooth that out with 180,320, and then prime them and wet sand them with 400 grit and then u should be good to bolt up the stock bumpers and side skirts and etc so get that rex back to stock If you need any help man pm me ill lend a hand. I went to school for body work so i know what to do and i have dericed a few civics!
          aircraft remover. enough said. get it at any autozone.! put it on let it chill for like 2m minute and start peeling.
            Bump good info right there Greg, Try it out
            Dc <3'r
            Viva Portugal
            Honda-Tech S/n- Mikeb353
            ClubIntegra S/n Mikeb353
            Dc <3'r
              not enough said. cuz that wont work!
                itll just ************ up the paint,
                !!!!!ThE GoOd DiE YoUnG!!!!!
                  Call me up man 203-215-8996.. Ill have no problem lending a hand. Or i can step by step you to get that thing back into shape. ive done it several times!
                    ur smokin crack. im gunna go try it on ur hatch. ill send you pics in a minute. ur cars gunna be sheet metal grey. :p
                      If that worked dont you think peopel would be scooping up stripper by the gallon...
                      Its a CRX.. most commonly rotted rusted car on earth... dont take all the bondo off because if there was rust its under there dotn open a can of worms just work around it!
