need help(located in e.hartford)
  • need help(located in e.hartford)
    hi,i am in the process of taking my engine out of my car and my axle nut is seized,tried every thing ,four foot pipe on the breaker bar but didn't work long story short i need to borrow an electric impact gun if any body will let me borrow it,rent it either way my luck i have a compressor and all the tools but don't ve 220v supply so i am just stuck...i am located in east hartford ,my number is 860 402 4977,text call please really desperately need help,thanks
    CGP CL9
    1993 EH3
    If u dont get it off tomorr ill come thru an take it off for u im in East Hartford too
    J-ROC TUNING
      no problem man will really appreciate it,do you have an impact gun or you got another trick?this thing is really bothering me,if you can do it tonight it will work too,i know it is asking too much but...
      CGP CL9
      1993 EH3
        glwyf bro
          I cant tonight But ill b around noon time tomorr
          J-ROC TUNING
            It happened to me with my hatch I had to borrow a torch and heat it then used a impact gun but my homie jroc knows his shyt he's the right guy for the job
            TURBO 2001 IS300
              i dout impact will take it off. u have to jack car up and put a punch in the rotor so it holds on the caliper preventing the hub from turning and jump on that bitch with a breaker bar and the jack handle over the breaker bar. this has never failed me
                [QUOTE=mark11017;653340]i dout impact will take it off. u have to jack car up and put a punch in the rotor so it holds on the caliper preventing the hub from turning and jump on that bitch with a breaker bar and the jack handle over the breaker bar. this has never failed me[
                thanks for the advise.
                CGP CL9
                1993 EH3
                  If the bolt doesn't come out your going to need a torch which i have heat the nut till its nice color, but be careful not to bust the wheel bearing and loosen the bolt!
                    torch that shit, and get a big ass breaker bar, always works for me
                      i wouldn't use a torch as your first solution. i'd save that till last if nothing else works.
                      just my opinion- i wouldn't want to be heating up/changing the characteristics of the grease in your wheel bearings by soaking the axle nut in heat to get it loose. try an impact first, or what mark said with the punch through the rotor.
                      590852836f5fbce940_b
                        when mine got siezed, took a torch, red hot, cut the bolt in half, and replaced rotor
                        Originally posted by nano0222
                          yea, that was a fun day, smh
                            torch n pb blast spray
                              if your motor matches your account name.... sell me your motor lol.
