Hey CTV I blew my k20 in a bad mis shift 5th to 2nd and I'm changing motors put. Problem is that every forum I check and everything on google says the motor comes out from the bottom...WTF!! I'm at home and im broke so paying a shop is not an option and I'm nervous of dropping my subframe . Sooo has any on pulled this motor out the top and can I get some input or advice please? .. Greatly appreciate any help thanx p.s car is an 02 rsx base 5 spd
Rsx engine removal help!!!!!!!!!!
Alot of them say that its easier from the bottom because its so easy to do it that way on a lift. Just like the 08 civic si. I do them at work all the time but it can be done from the top too. I just removed tbe engine from my Si at home from the top. No harder than removing it from an older Civic.
I just have to undo the suspension, axles, and mounts. I have removed the harness all my hoses and lines ,I broke the a/c line (fuck!). I'm pretty deep in to it . I dnt really see any issues other then clearence . I've never done a car like this ive always done single cams so I've been a little worried. Also how or where do I attach my chain from my hoist to the motor I dnt see any hooks??? Only one on the tranny.
Yeah watch out for that abs module id remove as much as posdible just to get enough clearance
Am not saying remove it lol just be careful where are u located btw?
