eg k24 help
  • eg k24 help
    When u drop a kseries into and eg with the hasport mounts, wat do u need to modify in thwe bay? For the mounts
    tt
      u have to cut off the tranny mount bracket
      eh9 jdm b16
      Pimpbays
        Cut the trans mount off. Drill 2 holes for the new mount bracket on th pass side rhru the frame rail. And make sure you have a crv post mount.
          I knew it had to do something with that.thanks
            I figured this is wat u had to do...how do u kno exactly where to drill the holes?
              Tt
                I'm guessing once u put the hasport bracket up to the frame rail it shows u?
                  there is a spot u bolt the mount to one u do it shows u where to drill
                    thanks
