delete
2002 Rsx Type-S Redline Problem?
If the crank sensor is bad it is sending a message to the ECU to tell it to nit fire due to incorrect crank position.
Chance the crank position sensor and you should be fine unless the engine jumped time (which on K series is hard to do because it is a timing CHAIN)
The random misfire code is because of the crank sensor and the crank sensor code is causing the car to run in limp mode.RIP NHSWAPS13203
