motor mount ?'s ekk1 or ekk2
  • motor mount ?'s ekk1 or ekk2
    whats the diffrence in the ekk1 mounts and the ekk2 mounts
    i am swapping the k24 into my ek coupe. whats the best choice and what will work because on k-tuned.com they say the ekk1 are for ek subframes and the ekk2 are for eg subframes??? need help asap
    it positions the motor differ. but like it says you have to use a eg sub frame. a lot of ppl use the eg sub frames. Google is your friend. Remember that.
        so i should get the ekk2 mounts and get the eg subframe??
          cause i am swapping this into a 96 ek
            Bump for Google.com dump the ek nd get an eg lol
                will the eg subframe bolt into my ek??? i wanna use the ekk2 motor mounts
                  yes you want to use ekk2 mounts. ekk1 mounts position the motor to close to the front of the car and an rbc barely fits. also ekk2 give better axle angle. yes you need an eg subframe on your ek to use the ekk2s and it bolts right up! hybrid racing sells a good set of ekk2s
                    Well i am in the process of doing the same swap i went with the ekk2 mounts from hybridracing.com, it gives way more clearance for your intake manifold and all that good stuff.
                      use the ekk2 mounts .. i had both .. the ekk2 push the motor back a lil more so you have more room to run a full size radiator and any intake manifold .. plus they axle angle is much better ... the ekk1 have little clearance to the radiator support and the axle angle is horrible
                      **Only The Good Die Young**
                      ***RIP NICK**
                        If you want to keep breaking axels use the ek 1 mounts lol
                        Save money on your electric bill - Make money helping others save money on their electric bill!
                        Contact me for details!
