k series engine specs...
This is a sticky topic.
  • k series engine specs...
    K Series
    K20
    K20A2 i-VTEC
    Found in:
    2002-2004 Acura RSX-S
    Displacement: 1998 cc
    Compression : 11.0:1
    Power : 200 hp (149 kW) @ 7400 rpm & 142 ft·lbf (193 Nm) @ 6000 rpm
    Trans Specs
    • 1st 3.267
    • 2nd 2.13
    • 3rd 1.54
    • 4th 1.14
    • 5th .92
    • 6th .73
    • Final Drive 4.4
    K20A3 i-VTEC
    Found in:
    2002-2005 Honda Civic Si
    Displacement : 1998 cc
    Compression : 9.8:1
    Power : 160 hp (119 kW) @ 6500 rpm & 132 ft·lbf (179 Nm) @ 5000 rpm
    2002-2006 Acura RSX
    Compression : 9.8:1
    Power : 160 hp (119 kW) @ 6500 rpm & 141 ft·lbf (191 Nm) @ 4000 rpm
    Trans Specs
    • 1st 3.662
    • 2nd 1.769
    • 3rd 1.212
    • 4th 1.14
    • 5th .92
    • Final Drive 4.765
    K20Z1 i-VTEC
    Found in:
    2005-2006 Acura RSX-S
    Power : 210 hp (157 kW) @ 7800 rpm & 143 ft·lbf (194 Nm) @ 7000 rpm
    K20Z3 i-VTEC
    Found in:
    2006 Honda Civic Si
    Power : 197 hp (147 kW) @ 7800 rpm & 132 ft·lbf (189 Nm) @ 6200 rpm (SAE corrected)
    K24
    K24A1 i-VTEC
    Found in:
    2002-2006 Honda CR-V
    Displacement : 2354 cc
    Compression : 9.6:1
    Power : 160 hp (119 kW) @ 6000 rpm & 162 ft·lbf (220 Nm) @ 3600 rpm
    K24A2 i-VTEC
    Found in:
    2004-2006 Acura TSX
    Compression : 10.5:1
    Power : 200 hp (149 kW) @ 6800 rpm & 166 ft·lbf (225 Nm) @ 4500 rpm
    Trans Specs manual
    • 1st 3.262
    • 2nd 1.88
    • 3rd 1.35
    • 4th 1.0
    • 5th .82
    • 6th .659
    • Final Drive 4.765
    K24A4 i-VTEC
    Found in:
    2003-2006 Honda Accord
    Compression : 9.7:1
    Power : 160 hp (119 kW) @ 5500 rpm & 161 ft·lbf (218 Nm) @ 4500 rpm
    2003-2006 Honda Element
    Compression : 9.7:1
    Trans Specs manual
    • 1st 3.262
    • 2nd 1.88
    • 3rd 1.35
    • 4th 1.0
    • 5th .82
    • Final Drive 4.765
    JDM K
    K20A – Japan Spec
    • HP 220 @ 8000 rpm
    • Torque 152 lb/ft @ 7000 rpm
    • Redline 8400 RPMS
    • Bore 86mm
    • Stroke 86mm
    • Comp Ratio 11.5:1
    • Displacement 1998cc
    • Specific output 110HP/L
    Trans Specs
    • 1st 3.27:1
    • 2nd 2.13:1
    • 3rd 1.57:1
    • 4th 1.21:1
    • 5th .97:1
    • 6th .78:1
    • Final Drive 4.765
    K20A - EURO spec
    • 147 kW (200 hp) @7400 rpm
    • Torque 196 Nm @5900 rpm
    • Redline 8100 RPMS
    • Bore 87mm
    • Stroke 86mm
    • Comp Ratio 11,0:1
    • Displacement 1998 cm3
    • Specific output 100HP/L
    Trans Specs
    • 1st 3.267
    • 2nd 2.13
    • 3rd 1.54
    • 4th 1.14
    • 5th .92
    • 6th .73
    • Final Drive 4.765
