tranny problem..
  • tranny problem..
    ok well heres what happens, shifting from first to second right before redline it rejects me and grinds real bad.. now if i let off the gas a little before i shift then it will go into second fine. i just changed the tranny fluid with enos.. still same thing. now i spoke to a tech at acura and he thinks another posiblity could be the clutch because this wasnt happening before the clutch was put in ( a month or so ago ) its a stg 2 competition clutch. another thing that i notice is when the car is ideling after about 10 20 seconds i hear a rateling noise which i think is the bearing but when i press the clutch in the rateling stops..
    04 type s
    I had the same simptoms as you did and the same clutch set up. I pulled my tranny down after the problems got worse and come to find out the damn spring popped out of the clutch disk. I upgraded to a CC stage 4 and havent had a problem since. Good luck.
      rattling mite b throw out bearing
        wat kind of tranny was yours same thing? and just dropped the car off at acura so getting it checked out right now
          i have the same problem but i have the stock clutch people think its my driving sayin i cant drive but i new it wasnt me....i heard it is the sinkcruels (however thats spelt) because now my tranny is hard ti get into first
            its a type s tranny
              it could be the pressure plate not lettin it get into gears..either way u will have to take it apart and just place a new clutch kit with pressure plate and bearings..im pretty sure its not the tranny..g/l
              Originally posted by knuckk
                Torched 2nd gear syncro. 95% sure.
                  my gsr tranny does the same thing i know its not k series but my synchros need to be replaced
                  !!!!!ThE GoOd DiE YoUnG!!!!!
                    kyle you could do a 2nd gear syncro in my tranny?
                      told you it was 2nd syncro :p
                        good sh¡t korea lol now to find who can fix this.. too bad you dont split trannys wtf... lol
                          i had the same problem. its the tranny. got it changed and doesn't make sounds now
                            i do but i wont... :p
                              bla bla bla
