h22 in 99 si help!!!!!!!!!!!!!
  • h22 in 99 si help!!!!!!!!!!!!!
    put the swap in everything is done right will not start no spark at all it getting power to the distrib to the coil and igniter just no spark from cap or wires help dot know what to do!
    You tried swapping Dizzy's? Do you have a known good Dizzy, & ECU Installed?
      yea it ran at first like shit miss firing than just died its jdm h22 distrib with odb1 jumper using the odb1 p13 ecu
        apparently everything is not done right eh?
        you had to rewire the dizzy and the injectors, and the alternator, check and triple check your connections. if all else fails the harness needs to be professionaly done.
        I DO REMOTE STARTS!
          im a professional. i could do it
            the car ran good on first start up for a while when we started it up a second time it ran ok then started to misfire then it died and i am a professional who wired it its not the wiring
            94 coupe gsr turbo-sold 98 coupe h22-stolen11 Denali- Daily
            01 ITR #37-project
              owerd...Where do u work outta?
                You had to rewire the dizzy and the injectors, and the alternator, check and triple check your connections. If all else fails the harness needs to be professionaly done.
                take it to nick (nhswaps) hes the one to go to ..he knows everything about swaps specialy h22s... He would have it fix in no time..
                JUAN'S_SLOW_EK
                !!!!!ThE GoOd DiE YoUnG!!!!
                  alright thanks for the input guys
                    im coming over tomorrow to fix this issue!!!!!!!!!!!!!!!!
                      bump cuz i found out it was the dizzy!!!
