H22 and h23 stroke difference
  • H22 and h23 stroke difference
    I need to know what makes up the differences in the strokes weather it's in the crank or the rods or the pin hight to top of piston need to put my motor back together and I want to use h22 pistons in my h23 and I need to know if the pin hight on the pistons is the same and that the rods and crank are different please help me! Can text me too if it's faster 2039421461
    google is ur friend bro lol
      I've googled the shit out of it I can't find out ahhhhh I'm freaking out bro thanks tho!
        found on a forum
        any h22 piston will fit an h23 block. If you can do it to an h22 (97 block pending), you can do it to the h23. Both have the same bores, deck height, and same cylinder material. Be weary of the piston compression height you choose because if you choose a 11:1 h22 piston, the stroke of the h23 crank and the relatively long rods considering the stroke will bump compression to the 12:1 range.
        for the amount of stroke and compression you are looking to run, i personally would run a little more aggressive cam than the mild crower 2. Skunk2 Pro1 seems like a good candidate.
          Ohhhhh baby you just made my day thank you sO much bro
            bump cuz u made me research and im learning shit myself now lol
            here:
              Thanks bro I needed this I miss my cb7
                H-Series and F-Series Compression Calculators by Zealautowerks.
                Follow me @bolacan413
                Follow the build @k_insight
                  Thanks awesome link^ bump
                    ~D Block~
                      yea u could use h22 pistons u just need to use the h23 rods
                      203 Crew Memeber # 57
