yea like the title says im tired of the b series motor so im thinking about doing a winter project on my eg. H23 i wanna know what parts i will need and what tranny should i use. i heared before about h2b but dont really know if i can use and hydro b series tranny. Help and also what ecu u would recomend on me using and yea i wanna make it obd1. i think the h23 motor is a 98 so what dizzy should be used. Thanks
h23 in eg coupe
Originally posted by Ej2nattoyea like the title says im tired of the b series motor so im thinking about doing a winter project on my eg. H23 i wanna know what parts i will need and what tranny should i use. i heared before about h2b but dont really know if i can use and hydro b series tranny. Help and also what ecu u would recomend on me using and yea i wanna make it obd1. i think the h23 motor is a 98 so what dizzy should be used. ThanksLast edited by TypeSHLude; 08-01-2012, 08:19 PM.MR Automotive
Dave's Tuning FTW
Since your already b swapped I suggest you do h2b. With an h2b kit you can use b series mounts axels tranny clutch flywheel basically everything. If you don't want to buy a dizzy you can swap the obd2 internals to obd1 internals and obd1 injectors. You can use ur stock harness and wire up the air temp sensor on the intake obd2 sensor that way you can use the obd2 intake many
