hey i need to pass emissions and i failed horribly my regustration exspres the 7th wich is two days....now im not trying to rush into ficxing it b4 then but like a week or so if its possible...i bombed everything except the nox.....if somebody want to take a look and see if they can fix it let me no thanks
need mechanic asap
Which ECU were you using when you failed? Do you have a functioning Cat. Converter?13203
im using the stock h22 ecu.....and i havent took the cat off but its there so im 50/50 on if its bad or not....but the problem is im running really rich...so i just thought maybe some1 on here could fix it b4 i get rapped by a shop
