Need help on h22 motor question
  • Need help on h22 motor question
    I changed the bottom end on my 98 prelude had a bad piston on my h22 motor so i got a bottom end fron an older h22 the block i had used crank sensor the older block i put in does not i used the original head and all the wiring from the 98 motor finished the job now turns over but does not start checked and and have no spark theres current coming to the coil but its not sending it from there what can it be i checked the plug that goes to the coil and theres curent but wont pass from there i already tryed changing the coil and still no luck
    Crank sensor
      Swap the oil pump
          If swapping the oil pump isnt for u u can try the ckf bypass trick the b series folk use. google it homie, ckf bypass on b series. The jdm b series blocks dont have a sensor so they have to do this or swap the pump. Sidenote, If ur intrested in doing an ac delete i have the belt # on hand thats needed aswell ** is the block u used closed deck?
          96-ek hatch b20vtec - daily
