H22 Swap
  • H22 Swap
    wat do i need to do to put an h22 swap in an eg hatch???
    I hate when people put up threads like this. Google it you'll find plenty of write ups and walk thrus.
      Mounts.Axle wireing hardness n u got to cut I think is a inch or two on the frame where the.tranny mount mounts one to
        yea but the forum is called h tech for a reason
        and i was just asking a question
        instead of waistin your time and being an asshole you should hit the back button its save you time
          thansk bro
          but the guy im getting the swap said i need a new wire harness from obd1 to obd 2 idk and a new ecu ???
            and have to cut the box shifter box if not it wont take the gears
              If ur car is obd1 n ur motor is obd1 then u get a ex hardness n make the inj n alt n sum other plugs longer for it can plug up n not be short n if ur car is obd1 n ur motor is obd2 then u will have to get a ex hardness still make the one I just said longer n repin ur hardness to obd2 like ur motor but it easy that all I do mess wit h series all day Shit make good power wit little shit to it
                yea its an obd 2 but i want it to go in an eg hatch obd1
                  All u got to do is leave ur motor obd2 n rewire ur hardness n put the obd2 plug in the obd1 hardness n u know ur car no goin to start because of the crank sensor u have to wire that up to
                    G/l
                    WTF B @ real n!gg@
                    Real>Fake
                      Really?
                        no he dont please dont cut anything
                          u need accord mid shaft, da axles, h swap, any ecu with vtec, swap mounts, shift box and cables, accord fuel rail, and u have two hoses going to ur heating core u need to replace the small one with a bigger one,
                            read my shit
                            read my quote to u and if u have question message me im also doing the swap and know alot about it and where everything goes
                              thansk bro
                              any ecu and harnes is fine u going to add cut and lengthen wires the the only bitch about swap the disturbtor is diff but there jumpers for that oh u have to move pics around it ur plugs that u have to read up on im not dealing with that rite now
