H22 civic help
  • H22 civic help
    never done a H22 swap what is everything i need from top to bottom
    please Help
    Get the entire h22 swap and fuse box and ecu and engine harness and after market h series mounts drop it in then get Dave to convert ur civic to obd2 h series plugs then plug and play then get. Dave to tune it to factory ...
      Get everything and let Dave or kemar do it for u...
        google son!!!
          u dont need fuse box
            im doing a h swap to u need motor, tranny, avid mounts seat the motor straight rather than angle, avid axles (made for swap), shift cables and shifter, any ecu with vtec and get it tuned for ur setup, accord fuel rail because the h series the connection is on other side of fuel rail (wont reach), theres two hoses for heating core on the firewall the smaller hose wont reach so go get the long hose and get a deplicate of it to replace the small one, the wiring, u have to lengthen the alternator wire since the alternator is were the power streering is on the b series there more cut and adding etc:
              a 97-01 prelude fuel rail will work aswell.
              96-ek hatch b20vtec - daily
                im doing a similar swap (f20b) into my del sol.
                if i buy that and the mounts, axels, suspension, clutch n shit (doing a manual conversion), then that should be all i need as well right?
                  I always wanted to do this gl bro
                    Prelude fuel rail will not work
                    a prelude fuel rail connection is on the other side of the motor his hose wont reach he needs a accord fuel rail it is the same set up as b series
