So i have not a serious problem but i would like to fix it before the real cold gets in. I have a 91 accord and when i start it in the morning the idle dosent go high. Let me put it this way, you know when the car is cold, when you start it the rpm goes slightly over the 2 thousand rpm line and as the car get a little warmer the idle goes down, aventually goes to normal idle, well i would like to fix this problem because it takes to long to warm up now, can you imagin how long will it take in full winter any help will be apreciated thanks
Need help with idle
I'm having a similar problem but when I start my car its rite were its suppose to be when it just starts... then after a warm up it drops down all the way down to 0 or sometimes a little bit higher and I tried numerous times to adjust the throttle cable ill adjust and it'll be go at idle ill go to drive and it'll either stay high or go back all the way down idk what's wrong with mines either imma try a new throttle body and see or just takes mines off and clean the shit out of it idk not to thread jack but I also would like help LOLeh9 jdm b16
Pimpbays
Try cleaninq your iavc sensor or look for a short. . Cus I had the same problem . My car was idlenin real low even with cold start but figuring out the wire came out the iavc plug. .98Ex DD EJ8 ROADRUNNER
Originally posted by mark95 View PostI'm having a similar problem but when I start my car its rite were its suppose to be when it just starts... then after a warm up it drops down all the way down to 0 or sometimes a little bit higher and I tried numerous times to adjust the throttle cable ill adjust and it'll be go at idle ill go to drive and it'll either stay high or go back all the way down idk what's wrong with mines either imma try a new throttle body and see or just takes mines off and clean the shit out of it idk not to thread jack but I also would like help LOL
