Replacing Radiator help
  • Replacing Radiator help
    I'm gonna be changing my radiator on my 99 Prelude soon cause of leakage. It's an automatic H22A4, so will this job be as simple as draining my coolant/ antifreeze, taking out my radiator and replacing it. Or is there anything more specific I should worry about? Tips, advice, experience all welcomed, no BS it's a simple job I know but I've never had to replace a radiator -.-
    Thanks CTV!
    DO NOT FORGET to windex yur windows & amor all yur tires! Yur car will run smoother after that. When yur car looks good, it feels good & drives good = )
    Goodluck .!
      Goodluck .!
      Lol. Thanks?
        ur gonna have to disconnect the transmission cooler lines and possibly switch the fittings over to the new radiator depending if the new 1 comes with em or not. its easy tho
        BACK FROM THE DEAD
        FUNCTION > FORM
          Thanks, I'm reading about that right now. Damn auto trans lol. Hpe to run an H2B...
            Originally posted by soysauce View Post
            Lol. Thanks?
            Lol i kidd i kidd
            But good luck with it bro
              Lol i kidd i kidd
              Haha, thanks man. It is fairly a simple job, but I don't get the whole bleeding idea -.-
                Just dont bleed the wrong way cuz then u'll need a BIG band-aid lmao im retarded i kno lmao
                  mad easy
                  research take your time done
                    bleeding it is simple; when your done installing radiator fill it up w 50/50 mix antifreez/h20. then with the radiator cap OFF run the engine with your climate control set to heat on blast and keep topping off the radiator everytime it burps (bubbles pop up). then when the engine is good and warm and theres good heat coming out the vents of the dash then top off the radiator 1 more time and put the radiator cap on and BINGO your radiator is bled. be sure to take the car for a ride after and verify that it doesnt overheat............
                    BACK FROM THE DEAD
                    FUNCTION > FORM
                      BTW do yourself a favor and get a new radiator cap too. you should always replace the cap when you replace the radiator;)
                      BACK FROM THE DEAD
                      FUNCTION > FORM
                        Hmm, thanks man!
                          Originally posted by Can~i~bus View Post
                          mad easy
                          Doing that right now ^.^ lol
                            Lol i kidd i kidd
                            ok kid
                              bt anyways bro changin the radiator is easy work once you see what u have to be it'll be like u have done it b4 lol easy job
