Radiator fan stayin on in my cb7
  • Radiator fan stayin on in my cb7
    I need help i got a 91 cb7 and my radiator fan is staying on i thought it was the relay so i replaced it and the fan is still staying on and killing my battery thru out the night need some help on what it could be
    just cut the wire nd ur all set but u should really look at ur thermostat housing nd see if the fan switch is melted or spliced maybe the wires r cut nd they r touching
      wait that would only work if the key is on so its something within ur fues box
        i had the same problem with a da i had relay was my problem but check the wires going to the relay and check fuse box cuz if u already changed the realy somthings giving it signal to stay on
          i have a coupe Fan switchs that sit in the thermosat housings if you guys need them hit me up for a price
          EM1-860-CTmember..1...
          J-SWAPS ....860-457-8335
