Car: 96 Civic Hatch
Engine: Bone Stock H22A4
Code: p0304 ( Missfire Cylinder 4
Idle Air control Code
Problem:
Car started out of no where to Rev up and down between 1,000 -2,000 and when the car is driven it runs fine.
Sunday I took the car to the track and the car started to have a missfire code P0304 but onces runing the car feel fine but idle you feel a light vibration.
Check:
-All vacumm hose nothing loose or crack or broken
-Clean Air idle control (wasnt dirty at all but clean it anyways)
-replace all spark plugs
Found: So Here is what I found onces I pull out the wire for cylinder number four the car idles fine and the missfire goes away! there is spark coming out the wire has a new spark plug. But if i put it back it goes back rough idle and the miss fire.
HELP ! any ideas !
Problem:
Check:
HELP ! any ideas !
