Help!!!!
  • Help!!!!
    What do i need to put an h22vtec head on an f22a1 block? i was told i need the belt accessories, what else?
    Please respond ASAP
    This requires drilling and welding to the head, not very cost effective if you are looking for a simple power gain. You are much better off just swapping a complete h22.
      x2 i know you have to weld shut a few oil passages but from what i heard you just dont make any real power, here are a few links from cb7tuner.com...this kinda swap most people call G22
      g22 turbo build
      G22/G23 info
      LoDollar92lx MRT
        The power gains are very minimal unless you are very experienced and plan on doing a full turbo build. Even then you are better off just doing a full build on a complete f22 or a complete h22, it will cost a lot less and it will be much more reliable
          I found this article that says diffrent, the guy used K pistons on stock f block and few other nic naks and made good power witout breaking the bank....BUT this guy knew what he was doing.
          K24 vtec vs g23
            yea there are a few guys on cb7tuner.com that have done g22 builds and have made good power but they are very experienced engine builders. for example: LoDollar built a g22 turbo setup and runs over 500whp on a daily driver.
              Yea Lodollar is in one of the links I posted, I personally never seen one but I do have a friend who did one but its boosted so as far n/a I wouldn't be able to help much.... lol by the way I think the op gave up once he saw all the work that needs to be done,
              Another alternative, jdm f22b swap would be nice ( that's what I have) plug n play and only for $500-$600
                its a lil work u got to do not as simple as it looks good luck imma do the same set up
                maybe we could run it wene ur done
                not everything from ebay is j.d.m!!
                  Yea your looking at like $3k just for the head swap when you can do an entire H22 swap for around $2k and your getting a lot more reliability with it.
