wat do i need besides the h22 long block the H2b kit and the b series tranny
H2b in A 98 hatch
U can use and h22 header but ull have to cut and reweld um that's what I did save 300 bux. And I would get the evo kit with mounts less of a headache and come with the flywheel instead of the spacer.. you'll need alternator relocater bracket and you will have get you crank pully cut meaning the ac part of the pully has to be cut off . good luck with biuld bro
