Need help: f22 content
  • Need help: f22 content
    I just scooped up a 97 accord se. It has a 95 vtec motor in it. I've tried lookin around on the internet how to set everything up n im not really finding any valuable info. From what I read, in order to pass emissions n all that shit I need a 96-97 motor to get things going forward. Can anybody shine a Lil light on this? I'm new to accords so any help would be appreciated. In the long run I'm lookin to swap over to 5spd also. Thanks again people
    Bump.. Hope you get the info you need.
      Good looks, bump
        What do you have for check engine codes... That car should pass easy...i do emissions.. I've had all year accords.. Whats the main problem you have..
          your gonna def need an oil pump from a 96-97 with the sensors as well, which include crank & i believe top dead center sensors.. then depending on what engine harness is installed you might have to wire them back to the OBD-2 accord ecu that u might need if its not already there.. if u need any assistance pm me.
          MR Automotive
          Dave's Tuning FTW
            find out what the codes are for and that is a start
            D and G auto member #5
              The cars not currently running. It seems like the car was an incomplete project so I can't get any codes. It has the non vtec ecu n harness right now. If it can pass emissions w a 95 (obd1) motor in a 97 (obd2) what else would I need to get it running properly.
