h22 p28 ecu ???
  • h22 p28 ecu ???
    wen using a p28 on a obd1 h22 wat will it run like everywhere i look says itll run good jus low redline and 160 hp help me out please??...
    if its stock its not gonna run great because its running on a 1.6 sohc map i would get it tuned and make like 180 hp if ur motor is healthy or alil more if u have good boltons and shit .. its gonna run but not as smooth
    D and G auto member #5
      thnx and how much do u think it gonna run me to get it tuned and im runnin a stock h22 wit 50k on it
        use a hondata s300 bro. if not why not use a stock p13?
          i have been lookin everywhere the cheapest i found a p13 was 300 bucks and it was way the f*#$ out there in like cali or orgeon some shyt
            just put up a thread and see if anyone on here has a obd1 p13 in the parts wanted section, the closest thing you can get that will make the car run good other then a p13 without getting it tuned is a p14 but you will have no vtec. p14 is the h23a1 non vtec ecu, same program, no vtec.
