Ok so my little brothers accord rpms are bouncing at idle. I changed the IAC valve problem still exist what could it be and how should i go about fixing it?All help is appreciated.
Idle problem need help!!!
FITV.. Located under throttle body.
Honda CRX / EF Civic (1988 - 1991) - How to fix your idleing woes! FITV IACV - I'm tired of seeing everyone ask the same question so here's a general list of things to do to troubleshoot your idle, focusing mainly on servicing the FITV (Fast Idle Thermo Valve). Also, if you have a bad thermostat this is the time to...
If not that check for vacuum leaks around the intake manifoldLast edited by mark11017; 01-16-2011, 09:17 PM.
If not that check for vacuum leaks around the intake manifold:cool: Luis Carrasco
