v6 from acura rl into an accord
  • v6 from acura rl into an accord
    my 6 cylinder is about to die. the only engine so far that able to find is the c35a from a acura rl with 3.5 engine. Now the real question is will this engine be able to drop in my car or will i have too move the motor mounts. they are from the same year, my car is a 97, engine is 97 so the wires should not be a problem... what about the mounts thats is what im concern with
    is da accord a v6 and what year is it becuz it does depend onit
      3.5 from a 97 rl is totally diff from the v6 in the accords. the early v6 accords use a version of the 86-90 legend motors. the next gen accords share the same 3.0 v6 with the 3.0 cl. the rl motor from that gen is very differnt
        hey people do k swap into civics and integras...try to find someone who has done this, not common but im sure someones thought of it, but good luck with it, if u do it its gonna be dopeee
        RIP Nick Haines
          no .. its not common.. it wont work.. one is a transverse set up and one is not.. it wont work..so it wont be .....dopeee...
          now if you wanted to try to put a 3.0 or a 3.2 from a tl or cl.. now that is possable...
            from what i can remember i didnt ask for an answer from you. and fyi just because the accords v6 is transverse and c35s arent dooesnt mean it cant be done. yes serious work. and ive seen alot of so called "impossible" swaps done...
            but like i said, it would be "DOPE" to do it. good luck with w/e u do dude
            RIP Nick Haines
              雷蒙磨
              四川雷蒙磨用于建筑垃圾处理,提高资源再利用 四川大地震,产生了大量建筑垃圾,如渣土、废砖瓦、废混凝土、废木材、废钢筋等。这些经过逐个 分类、四川雷蒙磨粉机用于处理加工后,可以再利用。 建筑垃圾处理用于洼地填充可不经破碎直接回填利用;建筑垃圾用于场地平整、道路路基的应根据要求破碎后回填 利用。 建筑垃圾破碎----由于建筑垃圾块状很大,都是些硬度比较大的物料,可以选用大型鄂式破碎机进行破碎,该破碎机进料口大、破碎物料硬度强、产量高、粒度均匀、结构简单、维修方便和生产成本低等特点,适合四川建筑垃圾破 碎。 建筑垃圾破碎----建筑垃圾,堆放比较集中,场地比较有限,而且交通不是很方便。黎明重工新推出的移动破碎站解决一系列问题。 首先该设备为移动破碎筛分联合体,对各种大型大块物料进行多级破碎。另外移动破碎站设备占地面积小,设备灵 活、方便,机动性强,可节省大量基建及迁址费用;能够对物料进行现场破碎而不必将物料运离现场再破碎,并可 随原料开采面的推进而移动,从而大量降低了物料的运输费用。移动破碎站配置灵活,可以根据实际现场设计改型 或特殊性移动破碎站,适合灾区建筑垃圾破碎。 建筑垃圾粉磨--- 经破碎处理后的建筑垃圾,可以进行粉磨,深层加工,支撑混凝土骨料,再次用于公路、房屋建设上 。 黎明重工生产的粉磨设备有雷蒙磨粉机、三辊研磨机、高压微粉磨粉机、直通式离心磨粉机三环中速微粉磨粉机和超压梯形磨粉机。在建筑垃圾处理,资源利用方面, 黎明磨粉机起到举足轻重的作用。责任编辑: frank 参与评论
                he didnt ask for a answer from you either.. he asked if it would work.. i told him.. no..
                as far as "impossable" swaps.. sure if you have enough time and tools.. almost anything can be done.. but from his post he does not sound like he is looking to be the guinni pig to try to make this swap happen.. he sounds like he needs a motor and had a line on this one and wanted to know if it would work..
                and thanks for the good luck with what ever i do:)... how long have you been working on honda/ acuras? or how many swaps have you done? ive been working on them and building them about as long as you have been alive...
                  the good luck wasnt directed to u....and ive been working on hondas/acura since i was 17 and it really is none of ur business how many swaps ive done just know that ive worked on them enough
                  RIP Nick Haines
                    if you worked on them and knew enough you would know that it wouldnt work..
                      I know that the front end on a 97 V6 accord is slightly longer to fit the V6, & I have heard people in eurpoe doing H22 Swaps into the V6 Chassis to make a more balanced Auto-X car. With the H22 motor sitting farther back in the engine compartment, & the nose being a little longer means better weight distribution & More room for a Hairdryer! HEHE!!! Another Custom Swap that will require R&D but sounds Bad Ass. As far as C35 Swap, In my opinion, not worth the Time & Effort. Another C27 will be fine for budget. The J32 CL/TL type s motor with 6 spd would also be bad ass.
                        If you want to get the C35A1 done then you should get the EG there is one on Ebayer for sale a while ago had the C32A2 in it, The differnce between C35A and C32A is the block, head and IM (intake maniford). Other than that you won't able to fit that fat ass C35A into your accord, C35A has a lay out like RWD car but its a FWD unless you have ton of cash to dump out, about the J32A2 I don't know if that fit into your AV6 since I think you got the 5th gen Accord, but with the 6th gen Accord then that motor swap would be simple lol.
