got a 98 ek with h22 can i use a stock p28
  • got a 98 ek with h22 can i use a stock p28
    i was wonderin if i can use a stock p28 or wat ecu do i use it a h22a4 in 98 ek hatch obd2 wire harness with obd 1 injectors and dizzy plugs with obd2-1 step down lil help
    obd1 p13 computer for a h22, i dont think a p28 will work, different air/fuel, no aib etc..
      I got a chip p72 on mines....BUT MINES IS N A BUBBLE (EG)
      [B][I]Go Hard Or Go Home!!!![/[/I]B]
        yeah there are alot of other ecu's you can chip and run h22 basemaps on, the most used one is the gsr ecu because of its wide range of tuning/hacking abilities and you will still be able to run your aib's on that ecu
          ^^^agreed.
          op, your best bet is too just get your car tuned on any obd1 vtec ecu....its a win/win situation
          Team T&W
          Winning is the only option
            p28 works just fine its better then a p72 trust p28 is the best vtec ecu u can tune you just need a tune to get the vamp right because when vtec kicks the fuel cut out its set for lower cc injectors ban
            2+2= 4Dr H22
              good looks that what i thought that p28 was the best
                i got a p28 for my h22a block/h22a type s head. Just gotta get a obd2-obd1 jumper harness and map it for an h series
                  hey wats up guys.... im new here i have a 94 integra with a h22a, my shifter goes in hard to the right, just wondering if u guys have any similar problems and maybe sum tips on how to solve it
