since it got cold in the last couple days my clutch been acting up.. i have fluid in trans. very clean.. i change clutch slave on trans mission and fire wall about 5 months ago.. i looked at fluid and it was alittle low and dirty.. .... anyone have any special way to get air out of system or to keep it from acting up...???
air in clutch system...
Originally posted by ManTyme View Postbleed your clutchCash given for OBD1 Virgin ECU's. Txt Me 860 394 8694
I use a break bleed tool for the same problem my level was low dirty and had air in the lines. I removed all the old fluid and put some fresh fluid in and then use the tool to bleed the line. It work great with out having to pump the shit out of the pedal and got all the air out of my whole system in like 5min you can rent it a Autozone for free2+2= 4Dr H22
