I got a h23 blue top with a spun bearing.. I don't no if I want to keep it or sell it... If kept it gunna be a all motor build to the fullest I got the h2b kit and everything.. I just want to no if the build would be worth it.. And I was thinkin about trying to stroke it use a k24 crankshaft but then wat would I use for pistons and rods...
H23 blue top
Ok well you can use a k24 crank but you would need to modifie the block it doesn't just drop in and you would need a deck plate for all that extra stroke and there's no one locally I would trust with that... And yes your ganna need k24 rods with custom pistons and custom head gasket.... To some it all up it's not worth the money for you to do all that just drop a k24 and your done or just rebuild the h23 with the stock crank... Or do a g23 and you'll save time and money... Lmk how things go for you witch ever way you go.."This year pockets will be empty, slicks will be on, and hearts will be broken"
